Oil Pump Pick Up Tube Install Help
Old Jun 13, 2008 | 04:56 AM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
I cant seem to get the Oil Pump Pick Up Tube in my new pump. What should I do get it in?
Kevin
Old Jun 13, 2008 | 07:56 AM
Big Dave's Avatar
Car: 1992 RS Heritage
Transmission: TCI 700r4
Re: Oil Pump Pick Up Tube Install Help
Put the pickup in the freezer overnight, or in a bucket of ice for a little while. I've heard of people putting the pump in the oven for a while as well. As difficult as it seems to get in, they can come loose, so make sure you tack weld it onto the pump.
Dave
Old Jun 13, 2008 | 10:39 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
What I did was slip a 5/8" (IIRC) wrench over the tube, and hammered on the wrench. The freezer/oven idea is a lot better though.
Also, if you don't have a welder, use a roll pin. Install it where you want it, drill it, then remove it all and run it through your parts washer, then reinstall and put in a roll pin. Don't drill completely through the oil pump, just through the "bottom" housing. That way the roll pin can bottom out against the "top" housing. (top = towards the top of engine. When you have the engine upside down like that it will be the bottom....)
Old Jun 14, 2008 | 01:43 AM
Engine: L98 350 TPI
I hope it will work. I tried freezing the pick up and it did not work, so I should try heating up the oil pump. I have no idea why it is so damn hard to get it in.
Kevin
Old Jun 14, 2008 | 10:43 AM
danandamy's Avatar
Car: 86 Camaro
Slip the wrench over the tube as suggested above and drive it on with a hammer. I've always done it this way with no prob. Once you get it on you'll need to set the pick up tube where it is about a half inch or so off the bottom of the pan then tack the pick up tube to the pump so it can't pivot down out of adjustment.
Dan
Old Jun 19, 2008 | 04:20 AM
Engine: L98 350 TPI
Thanks guys I got the pick up and all welded up last night.
Thanks again.
Old Jun 19, 2008 | 08:27 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
go to autozone and use there tool
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
drathaar907
Aug 6, 2015 04:20 PM
