oil pressure
Old Jun 18, 2008 | 04:31 PM
MN305TBI's Avatar
Car: 92 RS
Transmission: 5 stick gears
Axle/Gears: stock???
oil pressure
When I'm cruising and not beating on the thing the oil pressure is at 30, when I get after it my oil pressure drops to 0. I have only driven this thing for about 100 miles, I think the sending unit is bad or the gauge is shot. What is the best way (easiest) to check the actual oil pressure? If I need diagnostic tools please let me know where I can find them.
The car is a 92 305/tbi
Old Jun 18, 2008 | 05:00 PM
310IROCZ's Avatar
Re: oil pressure
To avoid the obvious check the oil. sound like it is running out. I am sure you have done it but thats what it sounds like
Old Jun 18, 2008 | 06:38 PM
MN305TBI's Avatar
Car: 92 RS
Re: oil pressure
just changed the oil 100 miles ago
Old Jun 18, 2008 | 07:41 PM
310IROCZ's Avatar
Re: oil pressure
my opinion would be to by an aftermarket gauge and try that. then you will have a new sending unit and working gauge for sure. if it still does it then there are other issues
Old Jun 19, 2008 | 08:34 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: oil pressure
take a valve cover off
when the oil gauge says 0 there should be no oil coming out of the pushrod tubes
if there is oil coming out then replace the sender
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
