L98 alluminum heads
Old Jun 13, 2008 | 11:04 PM
ozzman's Avatar
L98 alluminum heads
hi i have a 88 gta with the L98 engine with alluminum heads does anybody know what comp ratio should be and combustion chamber volume, is it 58 or 64 cc. I have a good set of pro action iron lightning heads fresh and ready minus the correct springs, they are 64cc with 220 int runners. i dont want to loose compression ! also changing the cam comps xfi xtremefi cams 260/270 -------560/555
Old Jun 14, 2008 | 01:30 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The L98 aluminum heads are 58cc. Since aluminum transfers heat more readily than cast iron, and heat = energy, you need more static compression ratio with aluminum heads than with iron to make the same power. 58cc aluminum L98 heads = 64cc cast iron L98 heads.
So, if your new heads are cast iron and 64cc, you're fine.
Old Jun 14, 2008 | 08:46 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: L98 alluminum heads
I look at it as you can use more compression with aluminum heads to make more power, but if you want to say it your way, that's fine.
I think you have more of a problem going from 170cc aluminum heads to 220cc iron heads. That's a huge increase in intake runner volume and it will kill your low end power. 220cc's are for 400+ cubic inch race engines, in my opinion.
lt500r55
Sep 1, 2021 01:30 PM
CRFred
Feb 7, 2016 11:39 PM
italiano67
Aug 31, 2015 06:04 PM
TheExaminer
Aug 19, 2015 10:07 PM
anesthes
Aug 8, 2015 09:37 PM
