Scary backfire at 5K, is my diag. correct?
Old Jun 14, 2008 | 11:37 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
So I was driving home from work and decided to get on it on the on ramp to the highway. top of 2nd gear at 5200 -- BANG!
So immediately I think "S#!T - there goes the motor"
Thinking I dropped a valve I coasted for a few seconds and watched the rear view for smoke. None came and I gave it a little more gas and kept going.
The Tach stumbled up and down along with engine bucking but long story short, I managed to get it home and the bucking and tach got better. No noises or other symptoms.
So I checked on my old friend thirdgen.org for some similar situations and came up with bad coil or module in the HEI. Luckily I had all those parts and went and swapped them out.
Fired up that night and drove around today and no symptoms at all.
What do yall think? Did I get the diagnosis right or is it going to crap out on me soon?
Car is 88 TPI with remote mount coil. Rest of info in sig.
Old Jun 14, 2008 | 12:31 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
Re: Scary backfire at 5K, is my diag. correct?
I think you're correct, and the module could have been the problem. The car prob loaded up with fuel for a split sec at high rpm and caused the bang. Espeically with the Tach acting up, unless the pickup in the distributor is going out.
Old Jun 14, 2008 | 07:12 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Well I replaced the pickup too. I guess I didnt say that above.
Replaced: Coil, Module, Pickup and Cap.
Eggplant Jeff
Aug 10, 2011 12:02 AM
upchuck86
Sep 29, 2004 08:21 PM
upchuck86
Sep 27, 2004 07:52 PM
ctandc
Sep 8, 2002 11:49 PM
Mark305TBI
Sep 13, 2000 08:19 AM
