How do I change belts on 84?
Old Jun 14, 2008 | 12:21 PM
kevingrealish's Avatar
Car: 84 Z28
Engine: 350 V8
Transmission: 5 speed
How do I change the power steering and AC belts on my 84 Z28? I just replaced the power steering pulley...hope I don't have to take that off again.
Old Jun 14, 2008 | 12:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The brackets have slots on some of the mount bolts, and the accessory (alternator, PS pump, AC compressor, etc.) pivots on others. Loosen them up, push the accessory toward the center of the engine. Remove the belts, install the new ones. Pull the accessory away from the center of the engine to put tension on the belts (some, like the AC compressor, have a square hole that you can put a 1/2" drive handle on it to hold the tension), tighten the slotted bolts first, make sure all mount bolts are tight when you're done.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
mustangdmurder
Aug 21, 2015 07:17 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
scottmoyer
Aug 9, 2015 10:18 PM
