stalling!! any help would be greatly appreciated
Old Jun 14, 2008 | 01:26 PM
seannana's Avatar
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: Stock 3.42
my 92 z28 5.7 will start up and run perfect. but when im driving and let of the gas the rpms begin to drop slowly into a stall. unless i 2 foot the pedals(just keeping the rpms up a little as i slow down). now i just installed a level 2 700r4 in the car a couple weeks ago. and during the install we cracked the speedometer drive gear very slighty trying to fit it onto the trans output shaft. it worked fine until the other day. the gear must have completely broke off because my speedometer is dead . and this is the same time the stalling began. but i was told that the speedometer gear breaking should have nothing to do with the stalling. so here i am looking for help.
Old Jun 14, 2008 | 02:18 PM
mouthforcombat's Avatar
Car: '86 Iroc Z
Re: stalling!! any help would be greatly appreciated
Yeah, I wouldn't think that would have anything to do with the stalling. The stalling is most likely caused by a poor air/fuel ratio which usually is the result of bad sensor/s, vacuum leaks, or timing. Is it throwing any codes?
Old Jun 14, 2008 | 02:38 PM
seannana's Avatar
Car: 1992 Z28
Engine: 5.7 TPI
its not throwing any codes. and if i stayed in first gear and just putted around a parking lot or something there is no stalling. only if i run through the gears and get off the gas. mind boggling
Old Jun 15, 2008 | 01:25 PM
seannana's Avatar
Car: 1992 Z28
Engine: 5.7 TPI
is it possible for the prob to be the trans itself? it only has a couple hundred miles on it
Old Jun 15, 2008 | 01:33 PM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Im not that knowledgeable when it comes to engines but maybe it could be the IAC, I had similar problems and it turns out my IAC was broken in half.
Old Jun 16, 2008 | 04:34 PM
seannana's Avatar
Car: 1992 Z28
Engine: 5.7 TPI
i guess i can give that a try. i went out yesterday in the Z for a bit and it seemed to do it less often but the rpms still died down awkwardly from time to time. my voltage is very steady tho
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Apr 21, 2020 08:44 PM
NinjaNife
Aug 23, 2015 11:49 AM
91REDZ28VERT
Aug 18, 2015 10:16 PM
formula_novice
Aug 18, 2015 08:48 PM
