help with vibration
Old Jun 14, 2008 | 10:13 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
help with vibration
I am not to sure where to post this but i guess i will start here. I finally got my car running the other day after installing the fast xfi unit. the car sat for over a year before finishing the install. Durring this time i also replaced the clutch (mcleod street twin) and flywheel. I have a stroker motor and i purchased a external balanced flywheel at first. I started the car and i had a vibration at around 3k. I than relized that i had the wrong flywheel and than purchased an internal balanced one. Well the vibration is still there and its pretty nasty. What else could cause a viberation. Nothing else is different except for the clutch and flywheel set up. Do stroker motors take a different kind of flywheel??
Old Jun 16, 2008 | 03:55 AM
smokefan's Avatar
Re: help with vibration
anyone??
Old Jun 17, 2008 | 01:30 AM
smokefan's Avatar
Thanks anyway. i found out what the problem was. Thanks again
Old Jun 20, 2008 | 08:47 AM
jab89rx7's Avatar
So how did you solve your vibration problem?
I have the same problem with my 305.
I had bought a external flywheel before I even knew there was a difference between internal and external. GM performance cataloge has a note that engines with one piece rear seals need an external flywheel (#14088646 or #14088650). Look up the same GM performance flywheels on Summit's and Jegs website and they list them as Internal balanced. Who's right?
Just this week I bought the light weight GM performance flywheel from Summit and I am in the process of installing it now, but I don't know if it will solve my vibration or not until I get it all back together.
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
