What head to buy?
Old Jun 16, 2008 | 03:59 PM
310IROCZ's Avatar
What head to buy?
not sure what head would work best. looking for the most power.
89' L98 short block(fresh) stock pistons. 286h comp cam eldelbrock rpm intake with 1850 holley. heads two to choose from.
1) set of reworked 58cc 601's with 2.02 1.60 ported and polished
2) set of 1968 292 camel backs( duble hump) with 63cc 1.94 1.50
what would flow better?
Old Jun 16, 2008 | 04:08 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: What head to buy?
camel backs would flow more, but do they have accessory holes for your PS pump, alt, etc?
If not, then the 601's will work. I wouldn't bother putting in 2.02's and 1.60's in them though (or has it already been done?)
Not the right head for those valves.
Old Jun 16, 2008 | 04:42 PM
310IROCZ's Avatar
the 601 are already set up with the 202's the camel back have no holes
Old Jun 16, 2008 | 05:18 PM
Sonix's Avatar
Car: 1982 Trans-Am
601's it is then.
Watch the CR.
Old Jun 16, 2008 | 05:38 PM
310IROCZ's Avatar
Do you think the 601's will support 375 to 400hp?
Old Jun 17, 2008 | 07:57 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I know they will, I've made very close to that with NO port work and 1.94/1.60 valves installed. Clean up the ports a little and you should be able to hit that with the right CR and cam. Those heads like a cam with a bit more duration on the exhaust side though.
601s are actually closer to 53cc, so be careful of compression - it can get out of hand pretty easy with these heads. They are really good heads though, I like them.
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
