89 Camaro RS 2.8 Oil questions.
Old Jun 17, 2008 | 03:48 PM
Mercury's Avatar
Car: 1989 Camaro RS
Engine: 2.8L MPFI. Soon to be 3.4L
Transmission: T-5 WC
My Camaro has a problem with oil pressure (probably because the bearings are worn out) and I'm coming up to my next oil change and need some advice on what kind of oil to run. When I first got the car about a year ago it had something like 5w-30 or 10w-30 and oil pressure ran low at about 10 psi idle. My dad insisted I run 20w-50 when we changed the oil when we got it. That worked decent in the winter months but now its that its summer I don't know if I need to use conventional 20w-50 again. From a cold start at idle the oil pressure runs about 55-60psi, but as the engine warms up it drops as low as 20-25psi. Long story short, should I stick with something like synthetic 20w-50 or should I run a lower viscosity oil?
Old Jun 18, 2008 | 12:38 AM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: 89 Camaro RS 2.8 Oil questions.
sounds like u need a rebuild bad...
Old Jun 18, 2008 | 11:47 AM
Mercury's Avatar
Car: 1989 Camaro RS
Yeah. The engine has been run pretty hard by the kid who owned it last. I figured though instead of putting the same old 2.8 down in there I would buy a 3.4L out of a 1993-1995 Firebird with the seats and dash, but until then I guess I have to keep my camaro running.
84z96L31vortec
Aug 20, 2017 12:16 AM
Derick15
Sep 17, 2016 05:28 PM
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
