stock cam specs??
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: stock cam specs??
The cam has a duration of 202 on intake and 206 on exhaust(both measured at .050) the lift is .403 for intake .415 for exhaust, and a a lobe separation angle of 114.5
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
Here is a link to the cam shaft data for our cars:
https://www.thirdgen.org/tech-data
Guest
Posts: n/a
Ignore the tech data, whatever is there is likely wrong. I'm not even going to go there and look what it says.
The stock cam in all 85 LB9's was the 'HO' cam, with the specs posted above. They only used that cam in 1985, and they only used the puny 'peanut' cam in 1986, then went to rollers and different profiles for stick and auto in 87-up to some point where they started using the same cam and it gets really messy.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
85 TPI's all have the good cam, not the smaller cam. 85IROC-Z is correct.
