over charging!!
Old Jun 25, 2008 | 06:44 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Transmission: custom 700r
Axle/Gears: moser 9" 3.90
over charging!!
this morning on my way to work my bat gauge was showing 18volts i pull over to check it out and it dropped down to normal. on the way home it did the same thing except it stayed at 18? any ideas?
Old Jun 25, 2008 | 07:01 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Probably time for an alternator.
Old Jun 25, 2008 | 07:06 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Re: over charging!!
only a couple weeks old but its poss i guess
Old Jun 25, 2008 | 07:13 PM
spray004's Avatar
Car: 1991 Camaro RS
Engine: 355
Transmission: BTO 700R4
Axle/Gears: 4th gen 3.73
Re: over charging!!
Sounds like the voltage regulator is bad or going bad. If the alternator is only a couple of weeks old then take it back to where you bought it from or take it to autozone and have them test it.
Old Jun 25, 2008 | 07:16 PM
five7kid's Avatar
More common than it should be.
Old Jun 25, 2008 | 07:39 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: over charging!!
also, the stock gauge could be going a little wacky... I would double check with a multimeter.
My s10's gauge would always be at 18 and sometimes drop to normal, but the alternator voltage was fine.
Old Jun 25, 2008 | 10:11 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Re: over charging!!
the post on the back of the alt. reads 30 volts with a multimeter but the batt is only reading like 12 volts.
Falcon50
Aug 22, 2020 03:26 PM
apie2546
Oct 16, 2016 02:24 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
RS Reaper
Sep 27, 2015 07:04 PM
