Fuel pump relay wires
Old Jun 26, 2008 | 05:18 PM
NY87Iroc's Avatar
Car: 1987 Iroc convertible
Axle/Gears: 3.42 posi
!987 Iroc, how many wires should there be on the fuel pump relay and what color should the wires be?...Thanks guys!!!
Old Jun 26, 2008 | 05:44 PM
NY87Iroc's Avatar
Re: Fuel pump relay wires
I think I messed someting up good. I think I found the right relay and I tried to jump the orange wire to the green wire to see if my fuel pump wold work but instead i jumped the orange to the black which I assume is the ground and I heard a snap like a fuse blowing but it was under the hood somewhere not in the fuse panel. Now I have no power to any of the relays..Is there some sort of fuse under the hood to check???
Old Jun 26, 2008 | 07:11 PM
ScottyB724's Avatar
Car: '91 Camaro RS
check for a fuse in a little black plastic container bolted to the inner fender on the passenger side by the battery
Old Jun 27, 2008 | 06:54 AM
NY87Iroc's Avatar
found it....thanks!!
Does anyone know what the relay between the battery and the radiator is ?for???
RazorN8
Jan 7, 2022 11:44 AM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Kaweh
Aug 9, 2015 02:54 PM
