weird rattling noise?
Old Jun 28, 2008 | 12:51 AM
Jix01's Avatar
Car: 1990 Pontiac Firebird
Engine: 305 5.0 TBI
Axle/Gears: 2.73 Open Diff.
sometimes when my car is idleing it makes a weird rattle like sounding noise.. if i step on the gas a little bit when it happens it gos away . my dad said that the same thing happened with my moms firebird and that it was the air pump.. which im geussing he meant smog pump. is he right or it something else?
Old Jun 28, 2008 | 01:50 AM
Ruiner's Avatar
Car: '91 Camaro RS
Engine: 355 TPI, Comp 268xfi, bowtie heads
Re: weird rattling noise?
My car made a similar noise at idle it turned out on mine it was the the belt tensioner, the bearing in it was shot and the pulley was rattling
easy way to tell is to put a screwdriver on the tensioner arm with the engine running and put your ear up to the other end of the screwdriver, you will know when you find the source of the noise
Old Jun 28, 2008 | 03:04 AM
Jix01's Avatar
Engine: 305 5.0 TBI
thanks, i will try that.
Old Jun 28, 2008 | 04:42 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
I had a PCV valve that did that once.
Old Jun 28, 2008 | 06:22 PM
Jix01's Avatar
Engine: 305 5.0 TBI
its too loud to be the pcv plus i replaced it already and it did it before and after the replacement.
db057
Jan 10, 2020 08:55 PM
jrdturbo
Mar 31, 2016 02:58 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
GouldyGTR
Sep 7, 2015 09:05 PM
