probs fuel and running
Old Jun 29, 2008 | 11:35 AM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
ok this past winter i had pulled my motor to fix a few probs. all new gaskets and bearings were installed. I had cleaned the ports on the heads i also installed a 6al box to replace the 6a. i put in a start/ retard box, new plugs, wires and a nos kit. I am running a holley blue pump and a mallory 3 port return style afpr with a 600cfm edelbrock carb. the nos kit is a plate kit.
now my car idles ok but starts to break up about 1500rpm and really falls down at 3k. i had tried to adjust my mallory afpr but i cannot get it to go lower than 9 psi. also i have tried to adjust the timing but it did not help the breaking up of the car.
i have adjusted the valves and tried the timing. i am not sure what else to do. any suggestions would be great. thanks
Old Jun 30, 2008 | 09:09 AM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Re: probs fuel and running
also i have noticed. but this always has been like this. i would set the timing with a gun and it would run poorly. if i used a vaccum gauge i could set it ad run soo much better. but the timing mark is WAY off the mark. the mark is at about 12 o'clock or so.
Old Jul 22, 2008 | 07:06 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
any ideas i am ready to push it into the road
Old Jul 29, 2008 | 09:39 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
bump
92camaroJoe
Jul 29, 2023 07:57 PM
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
