need help identify casting date on current block.
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
there were two numbers on the passenger side deck surface at the front of the engine. i have looked at mortec.com for like an hour and cant figure them out.
the smaller number is 13B0484491
the larger number is T1220CK1
i have no idea whatsoever.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: need help identify casting date on current block.
You're looking in the wrong spot. Casting date is on the block behind the driver side head.
according to mortec... "indicates the position of the ENGINE ASSEMBLY DATE/SUFFIX CODE and partial VIN code information on the front of the block. "
Engine: 383 Carb
Transmission: 4L60
Yes... assembly date... not casting date. Casting date is on the block behind the driver side head.
thanks. sorry about that, i thought the terms were interchangable.
is there any way that you can decode that?
Engine: 383 Carb
Transmission: 4L60
Someone can. I never bother with the stampings since they contain next to no useful information.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
13B0484491 = last numbers in the vehicle's VIN number. There are 17 digits in the VIN and the 10th digit is the year code. That means B is the year code. B = 1981. Are you sure it's a B?
T1220CK1 is the suffix code and I doubt the last digit is a 1.
T = Tonawanda engine plant
1220 = Dec 20
CK1 = ?
I can't find any CKx suffix codes for a 1981 engine and too many CKx numbers are used for many different sized engine. You'll need a casting number to narrow it down.
1220 = Dec 20
CK1 = ?
after looking closer, it would appear that the B is an 8, and the 1 is an L
L380484491
so that would be a 78 350, i am going to get the casting numbers off soon
L380484491
Engine: 383 Carb
Transmission: 4L60
Don't worry too much about the dates. All you care about is that it's a 350.
Car: 87 IROC L98
8 would mean 2008
It's possible that number sequence isn't a production number but a replacement engine number. If so then the year code means nothing.
skinny z
Oct 5, 2015 06:23 PM
Damon
Sep 26, 2015 04:29 PM
