Flush n fill
Old Jun 30, 2008 | 01:48 PM
fyrebird68's Avatar
Flush n fill
I wonder why engine blocks don't have a drain plug for antifreeze. Even when we drain the A/F out of the radiator, there's no way to get it out of the block.
Flushing a running engine with water pushes the old A/F out eventually, but then you have nasty old water in the block instead.
There's got to be a better way. What is it?
Old Jun 30, 2008 | 03:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Pull the water jacket drain plug from the driver's side of the block, and the knock sensor from the passenger side of the block.
A flush kit that hooks a garden hose to the heater hose works fairly well, also.
Old Jul 1, 2008 | 02:35 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Flush n fill
I replaced my block plugs (I don't have a knock sensor), with 1/4"NPT drain *****. That makes it nice and easy.
Old Jul 2, 2008 | 03:35 PM
fyrebird68's Avatar
Re: Flush n fill
Very cool. Where'd you get them?
Old Jul 2, 2008 | 03:42 PM
Sonix's Avatar
Car: 1982 Trans-Am
Re: Flush n fill
Canadian tire. Home depot, rona, etc also would have them. Just a copper/brass type of fitting.
sheachopper
Jul 31, 2019 11:27 AM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
HikoriYami
Sep 21, 2015 07:11 PM
corey8084
Sep 17, 2015 02:56 PM
