Can you drill 083's for use with pre-86 intakes?
Car: 1979 Camaro Sport Coupe
Engine: 350 LM1 with 083 2.02/1.60 heads
Transmission: TH350, soon to be 2004R
Axle/Gears: 2.41, soon to be 3.42
Can you re-drill the two center holes so that they are "straight" so you can use them with earlier intakes like the Holley 300-36?
Transmission: 4L80E/4L80E
Only if you filled the existing holes first.
It would be easier to modify the intake manifold bolt holes.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Can you drill 083's for use with pre-86 intakes?
Why not elongate the intake holes instead?
there pictures on how best to go about this?
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Just grind out the top of the 4 center bolt holes untill they are a long sausage shape. There are also wedge shaped washers you will probably need for this to work, so that the bolts clamp down the intake properly. I don't know who makes them though.
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
84 TA NV
Sep 6, 2015 08:02 PM
