Camaro Fuel Pump Question????
Old Jul 1, 2008 | 07:47 PM
aaronjohn20's Avatar
Car: 1988 Camaro IROC-Z28
Engine: 350ci
Axle/Gears: BorgWarner 2.77
I have a fuel pump out of an 89 Camaro RS with a 2.8 MPFI. My fuel pump went out in my 88 IROC with the 350 TPI. Can i use the fuel pump out of my 89 RS? Will it pump enough GPH, and will it pump enough pressure? The IROC is stock, other than a fresh rebuild.
Old Jul 1, 2008 | 09:18 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Re: Camaro Fuel Pump Question????
The short answer is no. They call for different part numbers. The pump bodies themselves will interchange, but they won't be able to support the 5.7L engine. So, if you do it, you'll be replacing it again before long. I definitely do not recommend swapping it.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
Newguy91rs
Aug 7, 2015 09:51 PM
