head gasket 89 350 5.7 tpi
Old Jul 2, 2008 | 07:30 AM
mjrad's Avatar
i am doing a head gasket on my 89 iroc
the old gaskets appear to be in good shape ,cant really detect were it may have gone wrong
also valve s are white , and one cylinder is whistle clean,washed out
i decided to do this from a block test witch told me that there was
combustion gases in the coolant.
this car is stock
looking around for all input on this
thanks
Old Jul 2, 2008 | 08:27 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: head gasket 89 350 5.7 tpi
It's possible that there's a hairline crack in your head gasket between a cooling jacket and the chamber. It's also slightly possible that your head is warped. Less likely though. Iron heads are difficult to warp.
Go ahead and change your head gaskets. Just make sure you put sealant where you should and to properly torque your heads in the proper torque sequence.
Old Jul 2, 2008 | 09:50 AM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
I have seen alot of 89 and 90 year model engines blow a head gasket (on the passenger side ?). I have had good luck having the heads resurfaced and replacing the gaskets.
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
NWAsonoma
Aug 18, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
