dumb question on fuel injector wires please help
Old Jul 3, 2008 | 09:37 PM
whitenight's Avatar
I have a 91 ta with a 305 tpi and I changed the intake gaskets, I dont know much about tpi but I labeled everything and came up at the end to discover that the drivers side injectors numbers I put on were gone. Do the injector wires have to be in sequence like 1-2-3-4 or can they be crossed? one mechanic here tells me no and one tells me its ok to mix them up. it seems to run ok just didnt want to screw anything up. Any info greatly appreciated
Old Jul 3, 2008 | 09:42 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: dumb question on fuel injector wires please help
They are batch fire injectors. It doesn't matter if you mix them up as long as the left side stays on the left and right stay on right. When TPI injectors fire, the whole side fires at the same time then the other side fires.
bryan623
Mar 22, 2021 06:43 PM
jklein337
Sep 19, 2018 06:23 PM
NinjaNife
Aug 23, 2015 11:49 AM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
