new engine, some break-in questions
Old Jul 9, 2008 | 10:26 PM
davep_96's Avatar
Car: 1987 Trans Am GTA
Engine: 355
Transmission: TH-700r4
Ok so my new engine is in and we started it up and it overheats. I am in the process of flushing the system, but I had a few questions about general engine set-up. Its a 355 with vortec heads, comp cam, Holley 600 carb, edelbrock intake, non cc HEI dist...
1. I heard that if the engine is running lean/rich, there is a possibility of running hot/overheating. Mine is definitely running hot so how do you know if you are running lean/rich? How do you fix this?
2. What timing should I set it at? Right now we just had it set so it would run so that we could break it in, but im sure the timing could be off and I heard that can make you run hot. So what should we set the timing at? I had a timing light and the line on the harmonic balancer was right around 4-6 on the timing tab thats on the timing cover.
3. I heard that with an HEI dist that you shouldnt gap the plugs over .040, but vortec heads say gap them at .060. I gapped them at .040, so is that good or are those in need of adjustment? What signs would the engine show if the plugs need adjustment?
Old Jul 9, 2008 | 10:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: new engine, some break-in questions
Roller cam or flat tappet? What kind of rings?
Gap the plugs to about .045" or so... you could go more for a miniscule increase in power, but it's not worth worrying about.
Old Jul 11, 2008 | 09:43 AM
davep_96's Avatar
Engine: 355
Flat-tappet.
What should the timing be set to? I have a feeling that ours is pretty off.
As far as fuel goes, how do you adjust lean/rich conditions?
Old Jul 11, 2008 | 09:46 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
For a flat tappet cam, you must follow the break-in instructions of the cam manufacturer exactly.
Mixture is adjusted by jetting and tuning the carb. Check https://www.thirdgen.org/hei for setting up the timing.
How hot is it running?
Old Jul 11, 2008 | 10:00 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
A brand spanking new engine is going to run quite hot during break in, because the rings and bearings are all still "snug".
You are doing the correct break-in for your flat tappet cam right??
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
