Stalling - just drops off - 305TPI
Old Jul 12, 2008 | 10:45 PM
Crouchman's Avatar
Car: 1988 Iroc convertible
Engine: 305TPI
Transmission: T-5, swapped it in.
Axle/Gears: no clue, but I'll learn
I've got an 88 IROC 305TPI - was 700R4, now T-5. Was stalling before the swap at stops. Just drops - RPS may wiggle then just die. Somethimes just straight dies. Sometimes goes quickly to about 500RPM & recovers. Usually idling at about 1250, but can go down, up, down, up. After the swap, it now dies (most inconveniently) when I downshift into 2nd making a turn - for the most part. Can stall at a stop, but this is intermittent. Stalls alot or not at all. Have thrown parts at it without success. New mass air flow, had the new plugs/wires, etc when I bought it, power cleaned the injectors, ran injector cleaner in the gas, etc. Possible computer problem/bad computer? Any other suggestions? No fun to drive it. Losing power steering in the middle of a turn takes the fun out of it. But the T-5 swap was a great decision. Sooo much fun when it's running good. Thanks for any help!
Old Jul 13, 2008 | 01:21 AM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
Re: Stalling - just drops off - 305TPI
sometimes timing issues will cause that. also make sure to check rotor, cap, coil.
Old Jul 13, 2008 | 04:56 AM
nimrod_sixty9's Avatar
Car: '91 RS Camaro
Engine: 5.0 TBI
Transmission: Manual
Axle/Gears: 3.08
Sounds more like a fuel issue to me... Pump... filter..
Old Jul 13, 2008 | 09:23 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Nobody mentioned cleaning the throttle body or cleaning/replacing the IAC (idle air control)? Changing the TPS?
Old Jul 13, 2008 | 03:14 PM
yes like mentioned before it can be a fuel issue.
go by whats cheapest to replace first that way u dont have to shell out 100 bucks on a fuel pump, that id gladly sell you
anyways
fuel filter
cap
rotor
sparkplugs
Old Jul 13, 2008 | 04:15 PM
Crouchman's Avatar
Engine: 305TPI
did most of that, I think including the IAC. Did all the filters/fluids/wires/cap/rotor/synthetic, that kind of stuff when I first got it. Doesn't smell like it's combusting completely - can get whiffs of gas/smells rich at times. I think there is a timing issue...my mechanic thinks the timing bracket isn't positioned correctly, if I have that right. I think the computer takes over. He was thinking it may be a computer issue. Knock sensor wasn't even connected when I got it. Put in a new one. It does run like a scalded cat when it doesn't stall. And starts right back up after a stall. Is also slow to start after it's hot/warm. Cold starts on the 1st or 2nd crank. 2 or 3 cranks when it's warm/hot and has been shut off for a bit. Starts pretty much right up after a stall though. Go figure. Thanks for all the input.
Old Jul 13, 2008 | 04:34 PM
that happened to me all the time. it would stall, but turn on perfectly right after, turned out the timing was set to 4* atdc
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
amcnellis
Sep 16, 2015 04:16 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
