Rust on Camshaft
Old Jul 14, 2008 | 01:54 AM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Rust on Camshaft
There was some surface rust forming on the bearing lobes on my new compcams camshaft. No pitting or severe rusting going on however when I cleaned the rust off using denature alcohol and a very fine steel wool pad, then buffed the areas with a dremel buffing attachment the sreas that were rusted still remained stained a blackish color although the surface itself is perfectly smooth.
Please tell me this thing is still usable...
Old Jul 14, 2008 | 03:36 AM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
Re: Rust on Camshaft
aslong as you didnt take off alot of metal, look up the specs of the cam, and pull out your vernier caliper and measure it to make sure its still to spec
Old Jul 14, 2008 | 09:33 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Originally Posted by FireDemonSiC
bearing lobes
On the journals, or on the lobes?
Old Jul 14, 2008 | 10:53 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
What type of camshaft are we talking about?
flat tappets, on the lobes, should be a black color. It's the surface treating. Rollers, and flat tappets on the bearing journals should be shiny silver.
Old Jul 14, 2008 | 09:39 PM
Car: 1985 Z28
Were talking a flat tappet and It's on the journals.
The rest of the camshaft is fine since the journals are the only unfinished part. Sorry for being vague on the details.
But yes. 3 out of 5 journals had surface rust forming on them. the two end journals being the worst and one of the middle journals just having a "fine mist" of surface rust. I managed to get all of this rust off by buffing with a dremel buffing wheel attachment and then rubbing for a very short period of time with a fine steel wool pad and denatured alcohol. Mind you we are not talking anywhere near new finish or resurface polish here. Just a sort of spruce up existing surface polish.
Like I said all the rust is gone but the areas that did have it are stained a light black color.
Is this thing still usable? Do you guys need any pictures?
Old Jul 14, 2008 | 10:20 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If it was on a new cam, I would have returned it, but it shouldn't cause any problems.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Fireslash
Apr 11, 2016 06:43 PM
FueledSoul
Sep 30, 2015 09:18 PM
tcflint
Sep 27, 2015 05:58 PM
GTAman
Sep 26, 2015 02:01 PM
