Zinc sacrificial anodes
Old Jul 16, 2008 | 09:09 PM
Homer's Avatar
Car: 1991 RS
Engine: 305 TBI
If I can put one in my radiator to keep it from rusting, can I get one to wire to the frame and engine block to keep the car from rusting? If not, why not?
Old Jul 16, 2008 | 09:30 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Zinc sacrificial anodes
Doesn't work quite the same way - it works in the cooling system because of electrolosys (dissimilar metals in the system making it act like a battery of sorts) - electrolosys causes corrosion on the "weaker" metal, which in this case, would be the zinc pill - the zinc pill is what gets attacked first.
Old Jul 16, 2008 | 09:56 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Actually it works in nearly exactly the same way. You couldn't do it with a single lump of zinc in one location though, the electrical resistance of the steel would mean that it would have a limited range of protection. You'd need it in several locations. Maybe even a coating of zinc all over the steel, like if you'd dipped the whole thing into hot, molten zinc. I should probably get a patent on that.
Old Jul 16, 2008 | 10:47 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
That's crazy talk apeiron, that'll never work. Listen to the dreamer here, like one day they'll land on the moon
Homer, go into a boating store and ask about zinc sacrificial anodes. They do it a lot on boats. Just solder them on your frame at different points... Sure easier to just paint the thing though..
Old Jul 17, 2008 | 05:55 AM
black89ws6's Avatar
Car: 89 Formula, WS6
Engine: LB9/peanut cam :(
Sounds a lot like galvanization. Not sure, but I think that's been invented already
Old Jul 17, 2008 | 07:49 AM
Big Dave's Avatar
Car: 1992 RS Heritage
Transmission: TCI 700r4
I was wondering when someone would pick up on that.
Old Jul 17, 2008 | 08:39 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
He's such a wiseass, I love it
Hotrodboba400
Dec 10, 2019 07:07 PM
gixxer92
May 18, 2017 11:20 AM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
Saxondale
Sep 14, 2015 06:37 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
