Rear Gear Swap Questions
Old Jul 19, 2008 | 10:31 AM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Transmission: T5 non-W/C
Axle/Gears: 3.27 Open
I have a 1986 Camaro LG4 5 speed with the stock base rear end. It has a set of open 3.27s right now.
What are these rear gears 8 bolt 27 spline 7.75in?
I have a set of GM 3.73s, 10 bolt, 27 spline, 7.5in, with posi carrier. I believe they came out of an 88-91 camaro or firebird.
Are these gears going to fit in the stock 86 rear end?
And the 10 bolts are stronger than the stock 8 bolts or w/e right?
Old Jul 19, 2008 | 11:33 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: Rear Gear Swap Questions
The 3.27's are found in the 9 bolt rear end (number of bolts that hold the cover on).
They are made by a completely different manufacturer than the 10 bolt (ie: nothing inside will swap).
Count the bolts that hold the cover on your stock rear end and report back.
The higher gears for the 9-bolt rears are 3.70s.
Old Jul 19, 2008 | 12:57 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Wooh its a 10 bolt.
The guy that i bought the gears from did call them 3.70s. I just thought that meant 3.73s.
Old Jul 19, 2008 | 12:59 PM
Stephen's Avatar
Car: 87 GTA
The 10-bolt equal woulda been 3.23. Maybe that's what you have?
Check your cover bolts...9 or 10 bolts & NOTHING swaps inside.
Old Jul 19, 2008 | 01:07 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
yeah its a 10 bolt cover.
And yes 3.23s not 3.27s. I thought last time i checked the drivetrain list it said 3.27s. Oops.
Nothing Swaps inside a 10 bolt???
Old Jul 19, 2008 | 01:16 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
stephen help! Will the gears i have swap in???
Old Jul 19, 2008 | 01:20 PM
Stephen's Avatar
Car: 87 GTA
Depends on the years gears you have & the year axles you have.
I'm not 100% positive on 10-bolt years, but the spline count might have changed. I *THINK* they never changed, like the 9-bolts did, but I can't say FOR SURE.
Any 10-bolt guru's out there?
Old Jul 19, 2008 | 01:32 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
i don't think they changed either. As far as my research seems to show. It would be great if there were someone out there who could varify.
Old Jul 20, 2008 | 01:41 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I remember reading somewhere on here that 10 bolts had 26 spline axles until a certain year, @86-88 I think, after, they went to 28 spline axles. I just can't remember exactly what year.
EDIT: Here it is:https://www.thirdgen.org/forums/faq-...ml#post3801229
Old Jul 20, 2008 | 02:55 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
thank you
Old Jul 20, 2008 | 03:00 PM
Stephen's Avatar
Car: 87 GTA
See? I know the 9-bolts had changed the splines, but didn't know if the 10-bolts had.
Old Jul 20, 2008 | 03:10 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
go stephen haha. Yeah so i just counted the splines in the diff, about 5 times cause it was kinda difficult. Sorta dark and lots of little bumps, and i'm not good at numbers after 10..... But my carrier is a 26 spline. And my car is a 26 spline. So im happy. Is there supposed to be a little space in the splines. I think so, just making sure?
Old Jul 20, 2008 | 04:12 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
88 GM went to 28 spline ... but some of the 26s hung around into 89 or so I've heard. I bet counting those splines was a pain.
Old Jul 20, 2008 | 08:27 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
yeah not too much fun.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
mizz0313
Aug 12, 2015 06:45 AM
