engine valve train noise
Old Jul 19, 2008 | 11:25 AM
xyzman's Avatar
Just fired my rebuilt 355 (seems to make great power) 9.75 comp, 64cc non stock performance vortec heads W/550 lift springs, 700DP holley carb, dual plane air gap manifold and a lunati #60103lk voodoo cam 268/276 489/504 and stamped steel 1.5 roller rockers, now the problem, the engine makes all kinds or valve train noise, I heard this cam is a little loud due to the valves closing at a high rate and I also heard the stamped steel rockers are noisy too, comments thanks XYZMAN
Old Jul 19, 2008 | 06:51 PM
mawinc's Avatar
Re: engine valve train noise
Thats not a very big cam and it should not make noise. Check to make sure you adjusted the valves properly.
Old Jul 19, 2008 | 07:28 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
retainers hitting bosses
theshackle
Sep 17, 2020 08:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
B_Dubya
Aug 26, 2015 05:09 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
