Stainless steel roller rockers
Old Jul 19, 2008 | 03:16 PM
xyzman's Avatar
Any comments pro or con would be appreciated and are they as noisey as the stamped steel roller rockers, thanks XYZMAN
Old Jul 19, 2008 | 05:03 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Stainless steel roller rockers
more info , full roller , roller tip ? brand/make ? i installed comp cams roller tip , well worth time and money . i'm happy .
Old Jul 19, 2008 | 07:31 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
rockers wear out
new=good
Old Jul 20, 2008 | 07:43 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I have full roller stainless 1.6's.
Pretty heavy. Adds weight to the valve train.
A little noisier than the stamped steel.
No noticeable gains but then again it was part of a major engine build.
Old Jul 20, 2008 | 01:05 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
"Pretty heavy. Adds weight to the valve train."
Yeah, I just learned this recently. Your are better off with an aluminum roller rocker. You will notice that Comp Cams has quietly come out with a high grade aluminum roller rocker arm.
darwinprice
17
Oct 11, 2015 11:51 PM
skinny z
Oct 5, 2015 06:23 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Agent507943
Camaros Wanted
Oct 2, 2015 07:17 AM
Night rider327
Sep 25, 2015 04:47 AM
