coolent leak from back of motor
Old Jul 19, 2008 | 09:14 PM
ty85iroc's Avatar
have a 85 305 tpi and found coolent leaking off off my starter steady dripping. i checked the heater hoses to the firewall and they were fine. were else could it be coming from? thanks
Old Jul 19, 2008 | 09:19 PM
mawinc's Avatar
Re: coolent leak from back of motor
Check the intake gasket. Use a mirror if you have to.Make sure its not going in your oil pan!
Old Jul 19, 2008 | 09:38 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
theres a freeze plug right above the starter, youll probably have to remove starter to see it, later jimmy
Infested
May 22, 2018 11:56 PM
Andrew6.688
Dec 13, 2015 10:59 AM
TheExaminer
Aug 26, 2015 04:59 PM
cstrobel65
Aug 15, 2015 10:19 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
