xe 274?
Old Jul 20, 2008 | 12:01 PM
chevyrules85's Avatar
Car: 85 camaro
Axle/Gears: 342
xe 274?
im planning on using this cam in my motor, its a 350 with 9/75:1 comp, camel hump heads that have been pocket ported, aluminum intake with an edelbrock 600 carb and its a 2300 stall in a 700r4 with 3.73 gears, im planning on swapping to this cam and upgrading the exhaust at the same time to hedman long tubes and true duals 2.5 whole way back with bullets, would this cam be a good choice? i want something with a nice sound at idle and something that makes good power and torque, thanks guys
Old Jul 20, 2008 | 02:22 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: xe 274?
IMO it would be a great choice for that engine. I'm using it myself in a 350, 10:1 CR, 200cc World heads, RPM intake, 650 Holley, 4-spd. Works very well with my setup, which is not radically different from yours.
Old Jul 20, 2008 | 05:33 PM
Car: 85 camaro
Axle/Gears: 342
Re: xe 274?
thats what i thought, do you have 1.5 or 1.6 rockers? ill prolly go with the 1.6 rockers when i do the cam swap, how does your setup run? does it have a nice lope at idle?
Old Jul 20, 2008 | 05:36 PM
Air_Adam's Avatar
Re: xe 274?
1.5 rockers, Comp Cams Pro Magnums. Runs really nice, lots of power from about 1800+ and has some nice lope at idle. Its not 'rough' but its got a nice healthy lope to it.
supermaxxbasher
May 25, 2004 12:00 AM
AFatHippo
May 22, 2004 01:13 AM
therckid
Jan 7, 2004 06:42 PM
Pony Killer
Aftermarket Product Review
37
Dec 28, 2002 12:07 AM
Momar
Jun 25, 2002 07:18 AM
