Synthetic Oil VS low zinc
Old Jul 20, 2008 | 10:57 PM
Jonathan Dyer's Avatar
Car: '83 Berlinetta
Engine: 383 CI
Axle/Gears: 3.73, Eibachs, Tokiko Illuminas,
With all the talk of poor oil quality recently as mandated by the smog police does synthetic oil become a better option than mineral oil?
Jon
JSD MOD 20/07/08
Old Jul 21, 2008 | 09:14 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Synthetic Oil VS low zinc
Huh?
No, synthetic has even less zinc.
The only reason you need zinc in your oil at all is for flat tappet cams. Get a zinc additive and use it with whatever oil you choose.
Old Jul 21, 2008 | 11:37 AM
MN246's Avatar
Car: 84 Z28
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.73/Strange 12 bolt
If you're worried about zinc content, use Rotella. It has a very high zinc content since it is targeted at diesel engines.
Old Jul 21, 2008 | 12:33 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
I second this comment, the Rotella synthetic oil is excellent and will give you very good results.
Old Jul 21, 2008 | 11:20 PM
Car: '83 Berlinetta
Engine: 383 CI
Originally Posted by Sonix
Huh?
I had been wondering if a synthetic oil had any properties that would allow it to perform better than low zinc mineral oil for a flat tappet engine.
BTW Thanks bjankuski and MN246 for the Rotella recommendation.
Jon
Prodigious
Oct 4, 2015 11:20 PM
mddaniel
Sep 8, 2015 05:16 PM
1fast91
Sep 8, 2015 01:48 PM
RyanJB
Sep 2, 2015 01:27 PM
Navy8125
Aug 21, 2015 09:32 AM
