timing cover removal with a 1pc oil pan gasket?
Old Jul 21, 2008 | 08:38 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
timing cover is leaking. is this possible?
Old Jul 21, 2008 | 10:49 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: timing cover removal with a 1pc oil pan gasket?
Sure
Old Jul 21, 2008 | 11:55 PM
thanks Apeiron. but i guess what i was trying to get was pointers from someone who has performed the task secesfully? you know tips,pointers, that sort of thing?
Old Jul 21, 2008 | 11:58 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
For what, taking the timing cover off?
Old Jul 22, 2008 | 12:04 AM
taking the cover off, and replacing it without jamming up my oil pan gasket.
Old Jul 22, 2008 | 12:19 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Is it one of the aftermarket silicone 1-piece gaskets? Nothing to it then, just drop the oil pan, pull the timing cover off.
Old Jul 22, 2008 | 12:24 AM
its the felpro 1pc.
Old Jul 22, 2008 | 12:27 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No problem then. The silicone won't be stuck to anything, and the steel core inside will keep its shape.
Navy8125
Aug 21, 2015 09:32 AM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
MY87LT
Aug 17, 2015 08:43 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
gwade12
Aug 8, 2015 08:17 AM
