confused which sensor = cold start?
Old Jul 21, 2008 | 06:53 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
is it the one by the thermostat, or in drivers side head? i know one of these tells ecm what temp it outside correct? because it is cold blooded it starts right up, but i have to let it run for 5- 10 minutes b4 i even think of driving it and it isn't that cold out .
Old Jul 21, 2008 | 11:55 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Re: confused which sensor = cold start?
I believe the one in the head is the fan switch and the one in the intake is the coolant temp.
Old Jul 22, 2008 | 01:25 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
If you have an 89 vehicle with a TBI engine, you do not have a cold-start injector. They were only on 85-88 TPI engines.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
