seafoam + vacuum line = SMOKE!!!
Old Jul 25, 2008 | 11:42 AM
Jammin'Trey's Avatar
Hey guys I just emptied like half a pint of seafoam in my TBI 305 through a vacuum like and man is she a smokin sun of a gun. How long is she going to smoke now?
I let it sit and idle after the fact them threw a couple revs in there and she is still smoking like crazy!
Also I poured the rest remaining 1/3-1/2 a bottle into my valve cover oil fill hole.
I just changes my oil like a week ago. i dont want to change it again!!?!?!
Old Jul 25, 2008 | 12:53 PM
88I_R_O_C_ZTPI's Avatar
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
Re: seafoam + vacuum line = SMOKE!!!
the smoke is normal , its burning that stuff off. change your oil , that stuff will probably thin it out . i dont think you should put it in your oil to begin with ..
Old Jul 25, 2008 | 02:03 PM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
i dont really know how seafoam works but i wouldnt put it in my oil
Old Jul 25, 2008 | 02:04 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
It's fine. Run that stuff through your intake and it'll smoke like a banshee. Once you shut it off, then restart it, it'll puff some more. It'll go away after a few hours or less. No problems at all.
You put the bottle into your crank case, so after a few hundred klicks you should flush that out.
Old Jul 27, 2008 | 11:37 AM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
i put it in my crankcase once a year, but i run it for 5 minutes and drain immediately after.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 9, 2015 10:01 AM
snakeshooter
Sep 7, 2015 11:13 AM
Accerrito22
Sep 5, 2015 09:34 PM
rjcme
Sep 5, 2015 01:23 PM
