355 valve train noise vortec head
Old Jul 26, 2008 | 10:40 PM
xyzman's Avatar
My recently assembled 355 vortec head engine is making a heck of a racket and the noise is coming from the valve cover area, the springs are good for 550 lift and the cam is the voodoo 268/ 489-504 hydraluic. the rockers are the stamped steel roller type 1.5 ratio, the noise sounds like all the valves are loose, even though I adjusted them till I felt resistance at the push rod while turning it, and then 1/2 turn down, could a clearance problem, spring to rocker arm clearance be the culprit, also tried alum full roller rocker arms 1.6 ratio and the noise got worse but these showed marks where the spring retainer was hitting the lifter, also note that the poly locks on the steel rockers could only be turned a couple of threads down and then they bottomed out on the stud? comments suggestions thanks XYZMAN
Old Jul 27, 2008 | 10:53 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: 355 valve train noise vortec head
Originally Posted by xyzman
... also note that the poly locks on the steel rockers could only be turned a couple of threads down and then they bottomed out on the stud? comments suggestions thanks XYZMAN
You should check your valve train geometry, the pushrod length, and the rocker stud clearance to the bottom of the rocker.
Reading these threads will help:
THREAD
THREAD
THREAD
and learning how to use the little blue thing shown below:
Your pushrods are probably too short.
Old Jul 27, 2008 | 11:10 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Are you using self aligning rocker arms?
Old Jul 27, 2008 | 11:29 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The valve springs may be good for .550" valve lift but did you machine the valve guide boss shorter to allow max lift +.060" betweent he retainer bottom and the valve seal top? stock vortecs only accomodate around .470" a the max without modication. Did ya check after machining? Even machinists goof up. Hopfully all you did was mash the valve seals and bend the pushrods.
Old Jul 27, 2008 | 12:54 PM
xyzman's Avatar
yes
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bamaboy0323
Sep 3, 2015 06:07 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
