Roller rocker now valve covers don't fit
Old Jul 27, 2008 | 05:48 PM
89jim's Avatar
I just put on a new set of PRW stainless roller rockers and now my valve covers don't fit. I have room for the poly locks (I have tall type covers) The suports to the bolt holes seem to be the problem.Now what? Have any of you ran into this problem? How do you run center bolt covers with roller rockers? Thanks for any input.
Old Jul 28, 2008 | 06:39 AM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Re: Roller rocker now valve covers don't fit
They make tall valve covers for centerbolt heads, or adapters to put on perimeter bolt. either would give you clearance.
Old Jul 28, 2008 | 12:20 PM
snardos's Avatar
Car: 1992 camaro z28
Axle/Gears: 2.73:1
The supports on the tall valve covers I used had a wide base which had a hard time fitting between the rockers. I was able to wiggle them in there and once the base got past the rockers there was adequate clearance.
I found I could fit stock valve covers with roller rockers, although I never ran the engine that way, just to cover it up.
midge54
Dec 27, 2019 04:14 PM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
Street Lethal
Aug 12, 2015 11:33 AM
mustangman65_79
Aug 8, 2015 01:18 AM
