Fuse keeps breaking for interior lights and lighter
Car: 87 Irocz
Engine: 5.7
I need help!!!! I plugled my phone charger into the lighter and imediatetly the fuse went. So i tried replacing the fuse and as soon as it touches the spot were the fuse sits in it breaks again. I check the lighter itself but i cant figure out whats wrong. Any ideas?
HELP!!!
HELP!!! Last edited by Monica9; Jul 27, 2008 at 08:39 PM.
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: Fuse keeps breaking for interior lights and lighter
u have a short sumwhere or a bad ground thats causing the fuse to blow... u need to find it
Car: 87 Irocz
Engine: 5.7
i followed all the things wired to that fuse but i still cant figure it out. I will keep messing with it today and see if i can figure somethingout
Car: 1992 RS Heritage
Transmission: TCI 700r4
My car does the exact same thing. Fuse pops immediately upon putting in my cell phone charger. I don't even bother with it anymore, just make sure to charge my phone every night.
By the way, the cigarette lighter works perfectly, I smoke so it gets used often.
Please update us if you find the problem.
Dave
Dave
Car: 87 TA clone
are u sticking the correct amp fuse in the right place? maybe u should increase the fuse boy 5 amps. like if its a 10amp fuse increase it to 15amps. see if that works. cell phone DC chargers use about 2.5amp fuses... i kno that bc i tore one apart along with a radar gun etc... wat i did was i wired a 5 fuse block to the fuse panel but under the center consol and this allowed me to run 5 diff items with 2.5amps fuse for each item so i didnt have this ugly monstrosity of DC cigarette plugs at the cigarette lighter... also alowed me to run up 2 5 things at once with the saftey of each itembeing fused before the fuse panel.
Ghettobird52
Jul 5, 2024 11:18 PM
The_Phoenix
Feb 4, 2016 07:10 AM
