adaptor for 2 piece to 1 piece rear main seal?
Old Jul 27, 2008 | 09:36 PM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
I have a 383 crank for a two piece from a previously planned build that never came about. Now I am in the process of building the 383 but I have a 1 piece rear main seal block. Is there a conversion kit or some way to use the older style cranks in the newer style blocks?
Old Jul 27, 2008 | 10:19 PM
jeffcj's Avatar
Re: adaptor for 2 piece to 1 piece rear main seal?
Yep. Here are a few: http://store.summitracing.com/egnsea...7853&D=-157853
Might be able to find them cheaper elsewhere, I dunno.
Old Jul 28, 2008 | 06:46 AM
monte-ss's Avatar
Thanks, after I put in the post I kept digging and found the same ones. Now to determine if its worth it or if I should just sell the other crank and start with a new kit...
Old Jul 28, 2008 | 04:54 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
For what the adapters cost, I'd either get a new crank or a new block.
Old Jul 28, 2008 | 05:47 PM
jeffcj's Avatar
That's just a bit much to spend for what you get..
1992 Trans Am
May 10, 2023 07:19 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
Reborn756
Sep 4, 2015 03:42 AM
LT1Formula
Aug 20, 2015 09:36 PM
86White_T/A305
Aug 17, 2015 12:16 AM
