balancer timing reading
Old Jul 28, 2008 | 10:20 AM
jean's Avatar
Hi ALL,
What should be the timing reading on the 3 different generations of dampers from GM production ? I think one is pre 69 models , then 69-84 and then 84 and after . I know those 3 generations have the TDC located at different places and I'm reading 52 degrees initial on what should be set at 16 ... at idle and I'm pretty sure my 350 chevy from 1975 has a damper from post 84 . he damper is a 8"
Thank you all!
Old Jul 28, 2008 | 04:49 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: balancer timing reading
They'll all read the same when they're each used with the correct timing comb.
Old Jul 28, 2008 | 06:04 PM
jean's Avatar
right but on my case I have a 350 chevy 1975 with probably a post 84 damper so that's why I need to figure out how many degrees I have to read off to get the real one...The timing tab is about at 1pm-1.30 pm facing the engine and I think the 305 LG4 FROM 1985 from where the damper is out had the tab on top middle.
Old Jul 28, 2008 | 09:32 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Use a piston stop and make a new TDC mark on the balancer. It'll be more accurate anyway.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
midge54
Dec 27, 2019 04:14 PM
italiano67
Dec 11, 2016 09:21 AM
