Power Steering Line
Old Jul 28, 2008 | 09:31 PM
FastPhoenix84's Avatar
Car: 1984 Trans Am
Engine: 305CID - Bored .40"
Transmission: TH700R4
Power Steering Line
Im in the process of replacing the rubber power steering return line, noticed that the return line comes from the gear box as a hard line then to a rubber line about 2 inches long then to a hard line again that runs all the way under the radiator then back up to the pump, is it normall for the return line to run that long. It was like that when i bought the car about 5 years ago, it is an 84 TA. Could I just run about a 12 inch line from the gear box to the pump... ? any advice would be helpfull.. Thanx
Old Jul 28, 2008 | 09:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Power Steering Line
That's the power steering cooler. You could use a shorter piece and omit it if you wanted to.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
backtothe80s
Sep 5, 2015 12:39 AM
mdtoren
Aug 23, 2015 12:52 PM
