did i have detonation??
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
about a month ago i had readjusted my valves and after all the cranking to find tdc i guess when it started a loud explosion happened out of the exhaust (louder than a shotgun) and blew a hole in my rustmaster. Car started after that and its running fine, but im wondering if i did any damage?? Because a week ago the same thing happened to my buddies cutlass and it cracked 2 pistons
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: did i have detonation??
bumping the motor over probably flushed some fuel into the exhaust, then when you started the car it ignited in the exhaust causing the explosion, no damage to the motor, its made to withstand combustions, the muffler, on the other hand...
detonation will f-up a motor, its caused my too high compression or crappy gas, ect, nothing you did would cause it.
Car: '89 IROC-Z
Engine: 355
that was my conclusion also, but i only began to wonder after what happened to my buddy
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
yeah wheni first started my motor i had the timing way off and had it backfire like that...very loud, shotgun blast.
no worries man, poor muffler tho
if you ever crank it over like that with starter, disconnect coil plug wire so no spark gets thru
MikeH
Nov 16, 2001 11:57 PM
