Braided fuel lines from hardline to tpi?
Old Jul 30, 2008 | 03:42 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I need help figureing out what fittings and such I will need to accomplish this. Basically my feed and return lines are very rust right under the master cylinder along the frame rail. What I want to do is cut them back to remove the rusted sections and then run braided line with -an fittings from the cut back lines to the tpi fuel rail. What will I need? Is there any easy way to attach the braided line to the hard lines? I have a good flare kit (snap-on) but it only does sae and metric flares.. Ideas and suggestions are welcome.. basically I need to know what I need to do it.. I have quite a bit of 6 and 8 an line laying around from another project so if I could use any of it that would be good..
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
Sanjay
Aug 12, 2015 03:41 PM
