Power Steering
Old Aug 1, 2008 | 03:13 PM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
Power Steering
I want to install an inline filter in my power steering system.
Can someone point out to me, which of the two black hoses coming out of the fluid cannister/pump, is the low pressure/ return hose?
There are two, one slightly larger in diameter, and one a little smaller, the smaller one is easily removable, by two clamps, the other is fixed to the system.
Thanks.
Old Aug 1, 2008 | 03:28 PM
jpeden31's Avatar
Car: 1984 z-28
Engine: 305H.O. L69
Axle/Gears: 3.73 G80 GT4
Re: Power Steering
alldata not showing that specific info, best bet would be to disconnect 1 line from the gearbox and see which way the fluid runs when you spin the wheel with it running... a bit messy..
the pressure during a test for checking it is minimum 1000psi so it shouldn't be too hard to see which it is
if i had to guess I'd say the larger line is the return
Old Aug 1, 2008 | 04:07 PM
Re: Power Steering
I had guessed the smaller one is the return hose, because it is fixed by two removable clamps, while the other, larger hose is pressed/fixed to the pump, so it can withstand higher pressure.....doesn't that make sense...??
Old Aug 1, 2008 | 04:10 PM
jpeden31's Avatar
Car: 1984 z-28
Engine: 305H.O. L69
Re: Power Steering
yeah it does, i should have ran out to look, stupid brain 1 sec lemme stab it with a q-tip
Old Aug 1, 2008 | 04:11 PM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
Re: Power Steering
Probably. But it's a GM so who knows. Why would you filter your power steering fluid?
Old Aug 1, 2008 | 08:14 PM
Trick414's Avatar
Car: 1991 RS Vert
Engine: LO3, 305, TBI
Re: Power Steering
The clamp side is the low side.
Old Aug 2, 2008 | 03:01 AM
Re: Power Steering
Overhere in Europe, lots of power steering systems fail, because of contaminated fluid.
So I want to filter the fluid in my Firebird just in case....!!
www.magnefine.com that's the filter I'm going to use.
Squeaky8791
Feb 5, 2020 08:29 PM
Vintageracer
Jan 10, 2020 05:33 PM
Chuck84TA
Jul 15, 2016 09:05 PM
evilstuie
Apr 14, 2016 08:52 PM
deracer
Apr 11, 2016 12:04 AM
