fuel pump
Old Aug 2, 2008 | 01:16 AM
fbirdroller's Avatar
Car: 1986 camaro z28
Engine: vortec 5.7
fuel pump
is the stock fuel pump in a 91 firebird 3.1 ltr enough for a 94 lt1?
Old Aug 2, 2008 | 09:07 AM
dstss's Avatar
Car: 1992 TA Convertible
Engine: 5.0 TPI
Transmission: THM 700
Re: fuel pump
Probrably not. May work but will likely keep you from getting the performance you are looking for. Remember bigger engine needs more gas and air. The factory pump for the 3.1 has a lower PSI shut off point and pushes 40 gallons per hour of gas. The pump for the 94 pushes 55 gallons per hour.
Old Aug 2, 2008 | 12:33 PM
Engine: vortec 5.7
Re: fuel pump
i should be able to hook up a fuel pump from a 94 caprice with the lt1 in it and it work fine though right? ...and it will hook up to the standard pickup from a carbureted 86 z28 just fine?
Old Aug 2, 2008 | 01:27 PM
dstss's Avatar
Engine: 5.0 TPI
Re: fuel pump
Go to this site: http://www.showmetheparts.com/airtex/
This is Airtex Fuel pumps online catalog. If you type in the application you are pulling from and you can bring up a picture. You can hopefully see if it will mount and connect the way you want it to. Their pumps are close to OE so should be fairly accurate.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
