another cam suggestion plz
Old Aug 3, 2008 | 03:14 PM
irocinblue89's Avatar
Car: 89 iroc
Engine: zz383/compcam/gmpp intake/holley770
Transmission: 700r4 w/all the goodies
Axle/Gears: 4th gen 3:23w/powertrax
I purchased this motor for 5500: http://paceperformance.com/index.asp...&ProdID=228282 and after reading archived threads on the zz383 the consensus is that the cam in it is just ok. Before I install her into my iroc I was thinking about doin a swap now instead of 3 months from now when its all in and I have drivin it and decide I want more. I plan on making a good street/track car. I have a 4th gen rear with 3:42's, mostly spoon suspension pcs and their frame ties.The specs on the came seem tame to me compared to some of the other members on here. I have a 700r4, have not picked the converter out yet (thinking 3500). Unless I am way off? plz any input would be great.
Old Aug 3, 2008 | 05:22 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: another cam suggestion plz
I'd say that's a good street/strip cam. I had a 246/254 dur @ .050 .558/.558 cam that was too much as far as it made little vacuum for the brakes. Those heads would probably rather have a cam that lifts .550-.600, but the duration starts too get a little much for the street at those lifts. Honestly, I'd say that you probably could get .5sec better time in the 1/4-mile pretty easily from a bigger cam, but I'm talking something like 250/255 dur @.050 and .600+ lift that you wouldn't like to try and tune or drive much.
Old Aug 3, 2008 | 07:46 PM
Car: 89 iroc
Thanks for the input. I have read more here on this forum and it seems that most feel the motor is just an ok setup. I (like everyone else) want only the best, but can only afford so much. A quick cam swap was wishfull thinking, and cheap. The price seemed good for a motor I can drop in now. No piecing together, no assembling. Just plug, tune and play. A power adder is looking better and better, but it will just have to wait till summer. Need to figure out my stall. And build the tranny.
Old Aug 3, 2008 | 08:45 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
I'm thinking either a 3000 or 3500 stall, and be sure it is a lock-up converter so it'll be no different once above 40mph or so. The book I have here calls that cam "high perf. street machines, 2000+ stall, gears, choppy idle." For the 2-3 tenths a cam might be worth, I'd wait until you get it dialed in first and then decide on power adder or not as that changes optimal cam numbers.
junkcltr
Aug 2, 2019 11:12 PM
transamgta87
Sep 1, 2015 07:07 PM
camaro71633
Sep 1, 2015 10:24 AM
inferno15
Aug 29, 2015 01:48 AM
drathaar907
Aug 6, 2015 04:20 PM
