89 Camaro L98 TPI
Old Aug 3, 2008 | 09:38 PM
marcus88's Avatar
Car: 87 GTA
Transmission: Automatics
89 Camaro L98 TPI
Should I look for/use a certain year model heads and block with my 1989 TPI intake?
Old Aug 5, 2008 | 11:38 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 89 Camaro L98 TPI
Yes, you want an '87 and newer roller cam block. The benefits of a roller cam far outweight the extra cost. For heads, you can use either centerbolt or perimeter-bolt style, but the centerbolt style is the newer design for later-model cars. An '89 TPI intake will have the center four holes at a different angle that matches the centerbolt heads, too.
Old Aug 5, 2008 | 11:41 AM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
if you are anywhere nearby i have the l98 out of my 89 IROC for sale cheap here in central texas... its a longblock...
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
matthew911
Aug 12, 2015 09:38 AM
