Casting Numbers
Old Aug 5, 2008 | 08:03 PM
marcus88's Avatar
Car: 87 GTA
Transmission: Automatics
Casting Numbers
Is there a site that I can go to and look up the block and head casting numbers? I would like to know what I am purchasing. The block # is 10066036 & the heads are 83417369. Any help would be greatly appreciated.
Old Aug 5, 2008 | 08:31 PM
RazorN8's Avatar
Car: 1987 camaro
Engine: 383 AFR heads
Axle/Gears: Ford 9" 3.70:1
Re: Casting Numbers
Mortec.com Do a search for this kind of thing. I've found at least a dozen places where this question has been answered. Your looking at a mexican made 350 motor that goodwrench sells as a crate motor. Those heads are a mystery to me. Maybe aftermarket?
Old Aug 6, 2008 | 06:00 AM
marcus88's Avatar
Car: 87 GTA
Re: Casting Numbers
On the heads he says that it also has GM13 stamped inside the head. I saw that it is Mexican built, is that good or bad? How can I find out if it is a earlier or later model block and whether it is a roller motor or not?
Old Aug 6, 2008 | 10:32 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Casting Numbers
You could ask the guy.... It's pretty obvious if it's a roller block, it'll have the tappet holes in the lifter valley.
If in doubt? Assume the worst. It's a 1977 hencho en mexico block, with 993 or equivalent heads.
The block is ok to use, the heads are junk. Just assume that and move on...
Linson
Oct 24, 2025 02:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
3.8TransAM
Sep 27, 2015 08:37 PM
