Say a plug washer went missing in the threads to the cylinder head...
Old Aug 6, 2008 | 12:51 AM
Destructimus's Avatar
Car: 1992 Firebird
Transmission: 700R4 with B&M shift kit
Axle/Gears: 3.23 zexel 4th gen
So I've been changing my spark plugs and noticed that some of the plugs are coming out with the washers missing. Not sure they were ever there to begin with, but being as how most of the ones that did have washer on them, had them up towards the tip like the washer had threaded its way up. My question is, how the hell do I check to see if they are in there, how do I get them out if they are in there, and since the new plugs don't use them, is it even that big a deal? Thanks.
Old Aug 6, 2008 | 12:52 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Say a plug washer went missing in the threads to the cylinder head...
Cast iron heads or aluminum?
Old Aug 6, 2008 | 12:28 PM
Car: 1992 Firebird
Cast Iron. Sorry, went to sleep.
Old Aug 6, 2008 | 02:56 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A cast iron head seals with a tapered plug seat. Somebody used gasketed plugs for an aluminum head. Try pulling the gaskets out with a pick.
Old Aug 6, 2008 | 03:23 PM
Car: 1992 Firebird
I'll give it a shot. I got two of them out by mistake when I was hooking up the compression tester. Hopefully it will work for the rest because I'm not even sure which cylinders the washers are stuck in anymore. Two of the washers came out of the same hole, so I probably wasnt very observant last time I removed the plugs..
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
db057
Aug 22, 2015 08:17 PM
