Quick Harness Question
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Will a tpi wiring harness from an 86 corvette fit a 305 TPI from an 86 camaro without any modifications?
Car: 2017 Chevy Bolt
Engine: 200kw
Transmission: none
Re: Quick Harness Question
Corvettes had the ECM under the hood, F-bodies had it inside. That would make it about 3 feet shorter with differant plugs. 1986 Vette should have the alum heads, that means the EGR was relocated, so there will be some differances I would say.
