vented gas cap?
Old Aug 8, 2008 | 12:32 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
vented gas cap?
Do all gas caps vent tank pressure if it gets too high? I am asking because I dont have a charcoal canister anymore and dont have a tank pressure relief valve. Is the stock gas cap going to baloon the tank or will it release pressure at a couple of psi or something?
If the stock cap doesnt vent ever - where would I get one that would?
Thanks.
Old Aug 8, 2008 | 12:35 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: vented gas cap?
stock, no vents from what ive seen, id go hit up a parts store because im sure they have one in stock
Old Aug 8, 2008 | 12:41 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Re: vented gas cap?
So what do I ask for? A pressure relief cap?
For example on this website I found, what is the difference between:
Pressure-Vacuum http://www.cgenterprises.com/fuelcaps/mgc819.htm
Vacuum only http://www.cgenterprises.com/fuelcaps/mgc825.htm
and non Vented http://www.cgenterprises.com/fuelcaps/mgc826.htm
I mean I think its that non Vented doesnt allow air or fuel vapor in our out ever, Vacuum only lets air in but no fuel vapor out and Pressure-Vacuum lets flow both ways.
I would be cool with a 2 way vented cap but I dont want it to vent at .00001 psi or something - that would be like leaving a non vented cap unscrewwed (loss of fuel due to evap costs $$$).
Last edited by 88305tpiT/A; Aug 8, 2008 at 12:45 PM. Reason: Automerged Doublepost
Old Aug 8, 2008 | 01:23 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Re: vented gas cap?
This looks promising - for 2nd gens:
http://www.parts123.com/parts123/yb....Z5Z5Z50000136d
Says its a vented cap whereas the 82-92 one says nothing about venting:
Old Aug 8, 2008 | 05:58 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Re: vented gas cap?
BTT
Old Aug 8, 2008 | 11:29 PM
PV9685's Avatar
Car: 89 Firebird Formula
Engine: 305 Vortec, Single-plane, 4 barrel
Transmission: T5, soon 700R4
Axle/Gears: 88 10 Bolt, Disc, Auburn, 3.23
Re: vented gas cap?
Most of the Gm gas caps I have from the 80's have a valve in the middle. I drilled one out to have it fully vented when I removed my canister setup, as you need to be able to let air in otherwise the tank will build too much vacuum I believe.. ie: fuel goes out, air displaces it.
I think the valve in the middle of the gascap is pressure relief though, if yours has one..
-Dave
Old Aug 9, 2008 | 02:58 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: vented gas cap?
mine doesnt, never have i seen a vented cap from factory on these, just goto the parts store and look at the gas cap section, match up one that fits and pick the vented one, pretty simple, or you can ghetto rig one by drilling it open
Old Aug 9, 2008 | 08:18 AM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Re: vented gas cap?
No drilling. What I think you want is one that vents inward at a very low tank vacuum to let air in and prevent tank vacuum but you also want the cap to hold some pressure in to prevent massive vapor loss. Well see if I can find one at the zone. If not I already tested the cap I already have and it seems to allow venting inward (vacuum relief) but I couldent generate enough pressure with my lungs to make it vent outwards. So I am not sure it will. Rockauto.com actually sells the adapter that emissions stations use to test gas caps. It has the gas cap thread into one end of it and a small hole in the other for applying pressure/vacuum. Maybe Ill just get that. Or I suppose I could take it to my emmisions station... hmm.
Hotrodboba400
Dec 10, 2019 07:07 PM
chazman
Aug 28, 2018 03:25 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
chazman
Aug 22, 2015 02:01 PM
