Fuel pump wont turn on after battery relocation
Old Aug 10, 2008 | 09:21 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I moved my battery to the trunk today and i have power everywhere. Motor will turn over fine but i noticed i have no fuel pressure. I then listend for the pump to kick on with Key On, and i get nothing
No fuel pressure at all.
All i did was move the battery to the rear. Here's what i did.
i kept ground strap from head to the chassis. This used to connect to stock battery neg terminal.
I moved battery to the rear and grounded it to the trunk floor pan.
Alternator is run directly to the battery. i have a cutoff switch between the battery and starter.
Car has power everywhere but the fuel pump. I also notice my ground switch to turn the fan on doesnt work now either. I checked fuses and relays and its not that.
I did accidently close the circuit between ground and positive while installing the cables. heck of a spark and flash but i dont think that will hurt anything. I also welded the nuts for the batter hold down clamps to the trunk floor, but i welded on the car before and nothing happened so i dont think that could have caused anything.
Could it be too many grounds or a bad ground?
Old Aug 10, 2008 | 11:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not completely familiar with your set-up or the original car configuration, but I believe the ECM power comes off of the battery cable. Did you hook that back up somehow?
Or, you might have fried a fusible link.
Old Aug 11, 2008 | 06:29 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: Fuel pump wont turn on after battery relocation
car is all original wiring, 89 TPI harness.
well the alternator wire originally went to the battery line...but there was a round connection of some sort that looked like a black cylinder with a small wire running to it as well. i thought it was just a holder but that small wire may be tapping into that power line. I'll have to try and see if that is the case
Old Aug 11, 2008 | 10:12 AM
five7kid's Avatar
That's the power to the ECM. The black cylinder is a fuse holder.
Old Aug 11, 2008 | 04:48 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
thats what i thought, i connected it real quick to power and sure enough everything turned on.
thanks
Old Aug 11, 2008 | 04:55 PM
five7kid's Avatar
Wow, a shot in the dark and right on target.
Every once in awhile, even a blind squirrel finds an acorn.
Glad that took care of it.
eightsixseven
Dec 16, 2024 01:50 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
djmarch
Aug 9, 2015 05:27 PM
Kaweh
Aug 9, 2015 02:54 PM
